02-20-2017 07:36 AM - edited 03-08-2019 09:25 AM
Hi all,
Can the UCS 5108, be used with out the fabric interconnect? and be used like a server ?
thanks.
Solved! Go to Solution.
02-20-2017 09:04 AM
The short answer is no as the Fabric Interconnects are a mandatory component of the UCS B-series server architecture.
There is an option to embed the Fabric Interconnects into the 5108 chassis for smaller scale deployments using the Cisco UCS 6324 FIs. This solution is known as UCS Mini.
http://www.cisco.com/c/en/us/products/servers-unified-computing/ucs-mini/index.html
Hope this helps
02-20-2017 09:04 AM
Hope this helps
