Qualys connector openning SSL v2/v3 connections
Feb 21st, 2017
Hello everyone,
We are setting up the Qualys connector for the first time and we have run into an interesting scenario. While attempting to run the qualys_connector.pl script the following messages are displayed:
SSL_connect:before/connect initialization
SSL_connect:SSLv2/v3 write client hello A
SSL_connect:SSLv3 read server hello A
SSL_connect:SSLv3 read server certificate A
SSL_connect:SSLv3 read server key exchange A
SSL_connect:SSLv3 read server done A
SSL_connect:SSLv3 write client key exchange A
SSL_connect:SSLv3 write change cipher spec A
SSL_connect:SSLv3 write finished A
SSL_connect:SSLv3 flush data
SSL_connect:SSLv3 read finished A
Tue Feb 21 10:13:16 2017 [INFO] Launching Report
Tue Feb 21 10:13:18 2017 [ERROR] Launch response: <?xml version="1.0" encoding=" UTF-8" ?>
<!DOCTYPE SIMPLE_RETURN SYSTEM "https://qualysapi.qualys.com/api/2.0/simple_retu rn.dtd">
<SIMPLE_RETURN>
<RESPONSE>
<DATETIME>2017-02-21T15:13:18Z</DATETIME>
<CODE>1903</CODE>
<TEXT>Missing required parameter(s): report_refs (this report requires a tar get)</TEXT>
</RESPONSE>
</SIMPLE_RETURN>
Understanding that our report is missing parameter (If anyone knows what that is, please let me know), what is also concerning is that the connector is opening a SSL v3 connection to Qualys. Does anyone know how to force the connector to TLS 1.x? I have included details of our environment below.
Host OS: RHEL 7.3
Perl version: v5.16.3
Perl modules installed with versions:
  • IO::Socket::SSL v2.046
  • XML::Simple v2.22
  • XML::Twig v3.52
  • Net::IP v1.26
  • YAML::XS v0.63
  • LWP::UserAgent v 6.19
  • Net::SSL v2.86
dohurd Thu, 03/02/2017 - 07:51
  • Cisco Employee,
This is a supported Host Input Connector.  You can open a TAC support case and get help directly from the support team.
Doug
