02-21-2017 10:00 AM - edited 03-08-2019 09:26 AM
I have 2 Cat 6513-E switches in a VSS configuration. Power redundancy mode is set to combined.
If I do a "show power switch 1" command, it tells me
system primary power used = 5142.90 Watts (122.45 Amps)
Is that the power draw for the power supplies only on switch 1, or is that the total aggregate power used by both switches?
02-21-2017 06:26 PM
I don't know the answer. If you do a "show power switch 2" and get a different answer, then I think you can assume it is for that one switch only.
ps. It will be 12.245 A. 122A would be enough to do basic arc welding.
02-22-2017 06:43 AM
if I do a "show power switch 2" I get the exact same reading (5142.90), which seems strange.
There are a handful more devices on one of the switches, so I would assume the power draw would be different
04-06-2021 10:15 PM - edited 04-06-2021 10:15 PM
The identical issue takes place with 10GE optics. I often exceed 10km with LR as you can see, and I frequently use ER optics on one side and LR optics on the other facet to stretch the loss finances even similarly.
