Redistribute Static route into RIP / VRF
info
I am having a little trouble redistributing a per user static route (PPPOE) into an instance of RIP running inside a VRF.
I am receiving routes from the neighboring router however the PPPOE static route is not being placed in the neighboring routers routing table.
Please see config below:
Current configuration : 606 bytes
ip vrf Greatham
rd 65001:9
route-target export 65001:9
route-target import 65001:9
interface GigabitEthernet0/3
no ip address
ip flow ingress
duplex auto
speed auto
media-type rj45
negotiation auto
interface GigabitEthernet0/3.108
encapsulation dot1Q 108
ip vrf forwarding Greatham
ip address 10.82.255.253 255.255.255.252
ip flow ingress
router rip
address-family ipv4 vrf Greatham
redistribute static
network 10.0.0.0
no auto-summary
exit-address-family
ip route vrf Greatham 0.0.0.0 0.0.0.0 10.82.255.254
ip route vrf Greatham 10.82.0.0 255.255.0.0 10.82.255.250
end
Routing Table
Gateway of last resort is 10.82.255.254 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.82.255.254
10.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
U 10.82.0.0/16 [1/0] via 10.82.255.250
C 10.82.255.250/32 is directly connected, Virtual-Access5
C 10.82.255.252/30 is directly connected, GigabitEthernet0/3.108
L 10.82.255.253/32 is directly connected, GigabitEthernet0/3.108
R 192.168.109.0/24
[120/1] via 10.82.255.254, 00:00:18, GigabitEthernet0/3.108
Any ideas would be greatly appreciated.
Chris
jgraafmans
You need to assign the VRF through a radius attribute.
Cisco-AVPair = "ip:vrf-id=Greatham",
Edit:
Sorry, I misread your post. Could you also post the config and show route of the neighbor router?
