02-24-2017 07:59 PM - edited 03-18-2019 12:48 PM
I am running TMS 15.4.0 and have an issue.
I delete&Purge systems from TMS. About 24hours later and some times sooner the system shows back up.
I have Auto Discovery in Admin Tools Off ??
How can I make sure systems that are purged don't come back and reconnect to TMS ???
This is getting very frustrating.
02-27-2017 09:36 AM
If the systems are pointing to TMS as their manager, they will repopulate in the "list", they should get added though, just show up on the list to be added. This will do From the help:
The Automatic System Discovery Mode setting controls what is done to the detected systems:
Note that Cisco TMS interprets a system that is not in any folder as being deleted (but not purged). If you have automatic system discovery enabled, but no default folder set up for discovered systems, the systems will be treated the same as if discovery was disabled.
03-03-2017 09:25 PM
Patrick ... thank you ... looks like what I need to do is delete the Folder that systems would go to.
So the fact they are in the folder doesn't mean TMS is going accept them until I go to add systems and add it right ??
VR
Chet
