CUCM 6.1.5 to CUCM 11.5 upgrade PCD
Where I can get PCD Prime Collaboration Deployment boot iso
We have ordered BE6k upgrade. should it arrive on the servers with the cucm iso ?
Aman Soi
Hi Ali,
you are correct.
you would get the same .I have captured the snapshot of same after order is placed through  PUT and under e-delivery u get the same.
regds,
aman
10 Replies 10
Aman Soi
Hi Ali,
you are correct.
regds,
aman
Hi Aman,
I have 2 questions only
1- I found there is supported releases for PCD as per this link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/pcdadmin/11_0_1/CUCM_BK_P00E3B55_00_pcd-admin-guide-115/CUCM_BK_P00E3B55_00_pcd-admin-guide-115_chapter_011.html#CUCM_RF_SEB1E0AA_00
I see cucm 6.1.5 is supported with Cluster Discovery
But I don't see it (6.1.5) under Upgrade Cluster (Upgrade Application Version or Install COP Files)
Is this mean I can't upgrade from cucm 6.1.5 to cucm 11 using PCD and I should upgrade  first to 8.6.1 ?
2- Also It states that PCD isn't compatible with Cisco UC Virtualization Hypervisor that is preinstalled in BE6k and BE7K and you must substitute a higher virtualization software feature level. Is this mean PCD isn't supported with BE6K untill we upgrade the license ?
Haitham
Hi Ali,
regarding your first query
a. the PCD DOC it is possible. Suggest opening TAC case
https://supportforums.cisco.com/discussion/12185996/prime-collaboration-deployment-migration-cucm-615-10
b. regarding license issue
Cisco Prime Collaboration Deployment is not compatible with all license types of VMware vSphere ESXi, because some of these licenses do not enable required VMware APIs.
Note
Cisco Business Edition 6000 and Cisco Business Edition 7000 servers are preinstalled with Cisco UC Virtualization Hypervisor. If you plan to use Cisco Prime Collaboration Deployment with application VMs on these servers, you must substitute a higher virtualization software feature level.
The following are compatible with Cisco Prime Collaboration Deployment:
  • Cisco UC Virtualization Foundation (appears as “Foundation Edition” in vSphere Client)
  • VMware vSphere Standard Edition, Enterprise Edition, or Enterprise Plus Edition
  • Evaluation mode license
The following are not compatible with Cisco Prime Collaboration Deployment:
  • Cisco UC Virtualization Hypervisor (appears as "Hypervisor Edition" in vSphere Client)
  • VMware vSphere Hypervisor Edition
regds,
aman
Great
So is there any work around for PCD with CUCM BE ? as to deploy the migration into 3rd party servers on compatible ESXi and then to move it to the BE UCS C servers. or to get a backup and restore it on newly installed cucm on BE servers ?
You can use other server and then move the VMs or do the DRS from those other servers. You can also use the eval license, the caveat is that doing that, means no Cisco support.
java
if this helps, please rate
I'll do the migration on third party servers to get the backup only then I'll install the cucm on the BE6k servers and restore the backup
So Cisco won't support the installed VM on the BE6k servers ? or what is the problem will be at this time to decide which path to follow .
No, I meant that if you use PCD with the ESXi eval license, it WILL work, however, doing it in such way, means there will not be any Cisco support if you run into issues.
java
My final query,
If I'll use the same ip address of my CUCM for the new servers.
Then I must shutdown the old servers at the time of migration. right ?
Or I can migrate with different ip address to keep both servers up at the same time to control the phone move to the new cluster after completing all related applications for the new cluster .
Also if required, I can re-change the new cucm ip address to the old one using PCD without any issues. right ?
Both servers will be up when you're doing the procedure, this means you need to spin up a lab network and use NAT for this.
The alternative, is to change the IP, and then change it to the original IP after the migration.
java
This is when you need to understand that UPGRADE is NOT the same as MIGRATION
The documentation is right, what you can do is MIGRATE
They're not the same, and they're not interchangeable terms
java
