EEM Scripting with Multiple conditions
Feb 28th, 2017
Hi Netpros,
I have created an applet which tracks the latency and takes the specified action if the same goes beyond the threshold. It is working pretty well but the point I just want to understand is that whether is there any option in EEM to check multiple conditions such as the specified condition should trigger only if
  • Latency goes beyond 100ms and Packet loss is more than 5%
  • Latency goes beyond 50ms or packet loss is more than 8%
The point I want to understand is that whether we can perform boolean operations within a single applet with two different conditions ?
Thanks in advance
Yaswanth
Joe Clarke Tue, 02/28/2017 - 08:19
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, you can.  EEM policies can have multiple conditions since EEM 2.4.  If you're using IPSLA for this, you will need two reaction configurations to track both latency and packet loss.  Then you can configure EEM to do an "and" trigger on both:
event tag latency ipsla reaction-type rtt ...
event tag loss ipsla reaction-type packetLossSD
trigger period 1
correlate event latency and event loss
yashvarmap Tue, 02/28/2017 - 19:58
Hi Joe,
Thanks for your response.
Could you please help me with an example which makes the interface Gig0/1 down when one of the conditions met [ either latency goes beyond 100 ms or packet loss is more than 5%] within a single applet.
Thanks in advance.
Yaswanth
