Manually Run EEM Scripting Problems
Mar 2nd, 2017
  • Silver, 250 points or more
Greetings,
 I'm trying to configure an EEM script with an 'event of none', so that I can manually run the EEM script. I basically have the following script configured on a router.
event manager applet TSHOOT
 event none
 action 1.0 cli command "sh run | I LINK"
 action 2.0 cli command "sh run | I LINE"
 action 3.0 cli command "sh log | I Controller"
 action 4.0 cli command "sh int x/x/x:0 | sec rate"
 action 5.0 cli command "sh controller t1 x/x/x | I [1-9]"
I can go to Privileged Exec mode and type "event manager run TSHOOT", it accepts the command but nothing happens. I put the "event none", since it's not really waiting on a trigger, and so I can manually run it. Am I doing something wrong? I don't see any output at all from these commands after I run "event manager run TSHOOT".
thiland Fri, 03/03/2017 - 20:51
  • Bronze, 100 points or more
EEM doesn't automatically run as a privileged user.  Try adding:
action 0.5 cli command "enable"
Best to see exactly what it's doing though by running a debug (make sure you're logging buffer is set to debug level):
debug event manager action cli
Joe Clarke Sat, 03/04/2017 - 14:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, enable is definitely needed, but EEM will also not print the results of the commands by default.  You need to add something like the following between each cli action:
action 1.5 puts $_cli_result
