03-04-2017 08:50 AM - edited 03-19-2019 12:11 PM
Hi Guys
I have a doubt about of is necessary perform a vmware disk size reallocation for upgrade 9.1 to 10.5. According the information, the size requirement are the same for both versions?
TIA
Cristian
03-04-2017 09:36 AM
No, assuming you have enough space
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/upgrade/10_5_1/cucm_b_upgrade-and-migration-guide-105/cucm_b_upgrade-and-migration-guide-105_chapter_01010.html#task_185DF9CA90D71878CA04577BC4CE4048
03-04-2017 10:25 AM
You can compare OVA requirements for specific OVA and version here:
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-unified-communications-manager.html
if you need to resize anything going up is supported i.e. adding vCPUs, RAM, expending disk size, going down however is not.
03-06-2017 06:13 AM
Dear All
Finally, for upgrade CUCM 9.1 to 10.5, I do not needed modify the disk size for vitual machine.
Thanks a lot.
Cristian
03-06-2017 06:18 AM
Exactly, all laid out on the wiki.
Please rate all useful posts, thanks.
Chris
