03-09-2017 06:09 AM
Hi all,
I have a question regarding LACP between ASR9K to Cat 4500 (IOS).
I never tested the setup before and not sure if it will work.
is the configuration below is sufficient to bring up the LACP between the router?
Cisco ASR9K bundle-interface config:
interface Bundle-ether10
cdp
negotiation auto
load-interval 30
dampening
shutdown
interface GigabitEthernet0/0/1/7
cdp
negotiation auto
load-interval 30
bundle id 10 mode on
lacp period short transmit 100
lacp period short receive 100
shutdown
interface Bundle-ether10.13
ipv4 address
encapsulation dot1q 13
shutdown
Cisco Catalyst 4500(IOS) port channel config:
interface Port-channel1
switchport
switchport trunk allowed vlan <vlans>
switchport mode trunk
load-interval 30
interface GigabitEthernet1/3
channel-group 1 mode active
Solved! Go to Solution.
03-09-2017 06:16 AM
you have "mode on" under the physical interface. This is used for static BE and it's not recommended to use in production.
You need "bundle id 10
03-09-2017 06:16 AM
03-09-2017 06:18 AM
Thank you smailmilak for the reply.
Will try the configuration.
