03-12-2017 10:29 PM - edited 03-21-2019 09:05 AM
We are using Cisco Switches, recently planning to roll out Cisco SPA phones. Cisco Switch supports CDP, what Vlan settings do I have to configure on the SPA phones?
On the cisco switch we plan to configure vlan 100 for data, vlan 200 for voice.
The below is the default setting on SPA phones, do I have to configure any? If we leave the below settings as default, is Cisco switch able to auto assign traffic to vlan 100 and 200?
Enable VLAN: No Enable CDP: YEs
Enable LLDP-MED: YES Network Startup Delay: 3
VLAN ID: 1 PC Port VLAN Highest Priority: No limit
Enable PC Port VLAN Tagging: NO PC Port VLAN ID: 1
Enable VLAN: | Enable CDP: | ||
Enable LLDP-MED: | Network Startup Delay: | ||
VLAN ID: | PC Port VLAN Highest Priority: | ||
Enable PC Port VLAN Tagging: | PC Port VLAN ID: | ||
03-12-2017 11:43 PM
Recommended practice is to have switch port configured in access mode delivering VLAN100 data (PC) packets untagged with voice vlan 200 (this voice packets are carried tagged). In such case CDP/LLDP should work.
I'm unsure the CDP will work as expected for you if you will configure switch port to be trunk carrying both 100 and 200 tagged. In such case CDP doesn't know which VLAN is voice and which data, so I assume it will not work. But try it.
03-13-2017 02:16 PM
I will configure the switch as 'recommended practice', in this case, on the SPA phones, do I have to alter these default settings?
Enable VLAN: No
VLAN ID: 1
PC Port VLAN ID: 1
03-14-2017 12:01 AM
It should work with CDP/LLDP turned on.
But before roll out you should test overall configuration by self - to verify it works according your wishes.
03-14-2017 09:17 AM
Could you please share details about the Cisco Switch you are using in this scenario.
03-14-2017 04:52 PM
switchport mode access
switchport voice vlan 200
switchport access vlan 100
03-16-2017 06:08 AM
I wanted to know the hardware and software version of the device with which SPA phone is connected.
Please share that...
