03-13-2017 05:35 AM - edited 03-08-2019 09:43 AM
Hi all
Can anyone tell me when looking at the dscp values, are the CS values also included?
Am I right in saying they are only there as they map to the IP Precedence values and are backwards compatible?
so for example CS1 is DSCP value of 8 ? which AF class would this fall into ?
cheers
Solved! Go to Solution.
03-13-2017 11:29 AM
Right, take note of:
These PHBs retain almost the same forwarding behavior as nodes that implement IP-precedence based classification and forwarding.
and
These PHBs ensure that DS-compliant nodes can co-exist with IP-precedence aware nodes, with the exception of the DTS bits.
Which is why I wrote "No, they are not fully backward compatible, but they can be used like IPPrec." I.e. a simplified version of the RFC info.
Basically the CS code points overlap between AF RFC and IPPrec. For example, in pure AF, AF4x doesn't really guarantee precedence over AF1x, but IPPrec 4 has precedence over IPPrec 1. In common usage, CS classes generally are treated like IPPrec for relative precedence and the related AF group "under" that class is too.
BTW, another example of how CS is different, consider the RFC for the scavenger class which uses CS1, which has less priority then BE traffic. If you use this RFC recommendation, CS is no longer backward compatible with IPPrec, even ignoring the DTR bits.
03-13-2017 06:10 AM
Yes. (NB:DSCP values range from 0..63).
Correct. None, CS is not an AF.
03-13-2017 06:52 AM
so CS does not fall into an AF? are you sure?
so what do they align to? so are you saying the below is incorrect ?
CS0 = ip precedence 0 = dscp 0
CS1 = ip precedence 1 = dscp 8 = AF11-13 (dscp 10,12,14)
CS2 = ip precedence 2 = dscp 16 = AF21-23 (dscp 18,20,22)
CS3 = ip precedence 3 = dscp 24 = AF31-33 (dscp 26,28,30)
CS4 = ip precedence 4 = dscp 32 = AF41-43 (dscp 34,36,38)
CS5 = ip precedence 5 = dscp 40 = EF (dscp 46)
CS6 = ip precedence 6 = dscp 48
CS7 = ip precedence 7 = dscp 56
03-13-2017 09:15 AM
Hello
Please review below- probably explains it better than I was trying to- which makes me wonder - if I cannot explain it in simple terms then surely I don't know enough about it!
Class-Selector PHBs (Defined in RFC-2474)
To preserve backward compatibility with the IP-precedence scheme, DSCP values of the form `xxx000,' where x is either 0 or 1, are defined. These codepoints are called class-selector codepoints. Note that the default codepoint is also a class-selector codepoint (`000000'). The PHB associated with a class-selector codepoint is a class-selector PHB. These PHBs retain almost the same forwarding behavior as nodes that implement IP-precedence based classification and forwarding. For example, packets with a DSCP value of `110000' (IP-precedence 110) have a preferential forwarding treatment (scheduling, queuing, etc.) as compared to packets with a DSCP value of `100000' (IP-precedence 100). These PHBs ensure that DS-compliant nodes can co-exist with IP-precedence aware nodes, with the exception of the DTS bits.
res
paul
03-13-2017 11:29 AM
and
03-13-2017 12:13 PM
Hello Joseph
i couldn't have put it any better that ! - lol
03-15-2017 04:30 AM
So when we talk about these PHB's and AF classes, what process or config on the router is looking into these classes and dropping them etc? Is it different on each node? or Is it the WFQ process that looks at the QOS values and drops them according to its value?
03-15-2017 05:34 AM
For starters, typically L3 network devices ignore ToS unless you configure them to do something with it. One Cisco exception that comes to mind is interface WFQ.
Depends on the QoS model being used. If you're using PHB, which stands for per-hop-behavior, each hop may have a different policy although generally those under the same administrative management have a similar or consistent policy.
That depends on the platform. Different platforms offer different QoS features, how they are enabled may vary (although Cisco has been trying to get them consistent by using MQC [Modular QoS Command line]), and how they are physically implement such features depends very much on hardware.
That's just one of many QoS feature implementations. What it does is based on its own "rules". BTW, WFQ only drops when its flow queues overflow. (I'm also assuming you do mean WFQ and not CBWFQ.)
03-13-2017 06:33 AM
Hello
My understanding is the Class Selector PHBs are values that can be understood by differential services and assured forwarding in similar regards to ip precedence values.
Thus:
res
Paul
