ACI routing to L4-L7 Firewall in L3 mode
How can we solve following routing design  on Cisco ACI?
Topology description
- We have a Frontend EPG with web server, built on top of a L3 Bridge domain 10.1.1.0/24. Default gateway 10.1.1.1 is provided by Cisco ACI.
- We use a L3 firewall using L4-L7 service graph. The corresponding interface with IP address 10.1.1.2 is attached to the Frontend EPG.
- The same firewall has a second interface with IP address 10.2.2.1. This interface is member of Database EPG, built on top of a L2 bridge domain (the IP address range would be 10.2.2.0/24, but since it is a L2 bridge domain, we don't have to specify it anywhere).
- Web server in Frontend EPG uses 10.1.1.1 (ACI) as a default gateway.
- Database in Database EPG uses 10.2.2.1 (Firewall) as a default gateway.
How can we instruct ACI to send traffic destined to subnet 10.2.2.0/24 to the Firewall IP address 10.1.1.2?
In other words, on ACI, how can we configure "ip route 10.2.2.0 255.255.255.0 10.1.1.2" ?
(As a workaround, we have to ad a static route directly to the Web server, but we'd rather keep it with just the default route)
Please see the attached topology diagram.
Alexander
Marcel Zehnder
You need an additional L3-Out in your demo-VRF and change the 10.1.1.2 interface on your firewall to a transit network. You also need to change the service graph then (one side epg the other side external network).
It maybe easier to deploy your firewall in transparent (L2, go-through) mode between the frontend and database EPG - but then you need to re-address the servers in your database EPG (default gateway will be 10.1.1.1 in bd web-server1).
Marcel
Hi there,
Where can a route be applied in case of a L3 virtual firewall?
In our case, this is a firewall on a VM domain integrated with the Cisco ACI fabric.
Alexander
