Warning message
Firepower Management Center REST API Submit Snort Rules
Answered Question
Mar 14th, 2017
Greetings Cisco Community,
I am looking to automate the process of adding intrusion rules to a Firepower device (FMC version 6.2.0). I was hoping to be able to use the REST API for this purpose, but looking through the documentation, it's unclear to me whether this action is supported.
Is adding Snort rules via the REST API supported? I apologize if I've overlooked something obvious.
Thanks in advance,
J
Correct Answer by neipatel about 5 months 6 days ago
J,
Today it is not possible to modify or Tune IPS policy with the REST API. To add and adjust Snort rules in Firepower Management Center you must use the UI.
All you can do with the API and identify and IPS policy and apply it to to rules.
Neil
Overall Rating: 5 (1 ratings)
Correct Answer
neipatel Tue, 03/14/2017 - 09:43
  • Cisco Employee,
J,
Neil
jfeild001 Tue, 03/14/2017 - 09:54
Neil,
Thank you very much for your quick reply and the clarification!
-J
nwilu0001 Fri, 05/19/2017 - 05:25
Hi Neil,
Following on from your response, would it possible to export the SNORT rules using the API?
neipatel Fri, 05/19/2017 - 05:58
  • Cisco Employee,
nwilu0001,
It is not possible to export the SNORT signature contents for a specific IPS rule with the API. It is only possible to identify and apply the Rule as a whole (By name and system generated GUID) with the API. For visibility into the rule you would again have to use the UI.
Neil
