Cisco Controller 2504i SSID
Chandana Abeysinghe Tue, 03/14/2017 - 12:08
I would check DHCP first. Next thing is authentication. What type of authentication do you use for the SSID?
aleopoldie Wed, 03/15/2017 - 12:43
You have to ensure you are configuring the good WLAN Security when adding the adding the WLAN on your settings.
AL
y.graziano Fri, 03/17/2017 - 04:54
Hi [email protected],
the answer is you can't do this in iOS based devices, if you clear the broadcast checkbox on the wlan configuration your device won't see the SSID again, even if it was connected to the SSID before.
the way to do it
configure the SSID manually, go to settings >> WIFI>> other networks and enter the SSID name and security (case sensitive).
BTW, if you're hiding the SSID as a security method, you can forget about it, it has nothing to do with security and it can be hacked in seconds.
pieterh Thu, 03/16/2017 - 06:55
after unchecking the broadcast on the controller,
did you also enable "connect when no broadcast" on the client ???
alternatively remove the wifi profile on the client and add manually again
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
