03-15-2017 09:57 PM - edited 03-01-2019 05:10 AM
Hi All,
Since we can configure same IP subnet in different EPGs in same BD. What is the path if the end points of those EPGs communicate where the default Gw is defined in external firewall?
03-20-2017 04:54 AM
If the gateway is outside, there is no need for a subnet under the BD, much less under the EPG
from a forwarding perspective, same BD with two different EPGs using the same subnet should be ok so long as they are different VLANs to the ACI side. at this point, traffic from subnet-A EPG-A will need pass through a contract to subnet-A EPG-B. if you need to communicate to the gw on an external device, that gets complicated.
would probably be best to use three VLANs, one for the external bridge network, the real vlan your FW is using, a VLAN for EPG-A and a VLAN for EPG-B and contracts between all of them. of course, all of them tied to the same BD
hope that helps
03-21-2017 01:20 AM
Hi Dpita,
Thanks for the reply. Do we really need to worry about the vlan concept in ACI? for the forwarding does ACI check and worry about the vlan configuartion?
Here you are proposing three vlans as below right. If iam wrong pls comment.
Vlan10 - EPG-A (IP Subnet 1)
Vlan20 - EPG-B (IP Subnet 1)
here does external bridge network means external EPG which connects FW?
07-25-2018 10:41 AM - edited 07-25-2018 11:42 PM
I have same issue but without external bridge.
I have this scenario:
Issue is IP 10.0.0.2/24 in EPG-A doesn't ping IP 10.0.0.3/24 in the EPG-B.
EPG-A and EPG-B are linked with a permitted contract.
If I change Network ID on one of IP, all works!
Anyone can explain that behavior?
Both EPGs are in the same Bridge Domain and it have only one subnet.
07-27-2018 01:35 PM
Hi Maurlai,
Why do you need to declare subnet in yours EPGs ? Do you want to share your service with other tenant, VRF ?
IP Subnet EPG specify which part of the subnet you wish to advertise. (Shared between VRF).
08-09-2018 06:04 AM
I don't declare Subnet in my EPG.
Subnet is declared only in the Bridge Domain.
I want to understand why 2 different EPG (containing 2 servers in same subnet IP) linked with a contract, they don't reach together.
Example:
Vlan10 - EPG-A (IP 10.0.0.2/28)
Vlan20 - EPG-B (IP 10.0.0.3/28)
EPG-A with contract to EPG-B and reverse.
08-09-2018 08:17 PM
What TEP address space are you using? Typically that subnet range is used for the TEP pool. If you didn't change the default 10.0.0.0/16. If you do show controller :
a-apic1# show controller
Fabric Name : calo-a
Operational Size : 3
Cluster Size : 3
Time Difference : 319
Fabric Security Mode : permissive
ID Pod Address In-Band IPv4 In-Band IPv6 OOB IPv4 OOB IPv6
Version Flags Serial Number Health
1* 1 10.0.0.1 14.2.104.228 fc00::1 10.122.141.98 fe80::5a97:bdff:fe5:dd5a
3.2(2l) crva- FCH1929V153 fully-fit
2 1 10.0.0.2 14.2.104.229 fc00::1 10.122.141.99 fe80::a2e0:afff:fe33:945a
3.2(2l) crva- FCH2045V1X2 fully-fit
3 2 10.0.0.3 14.2.104.230 fc00::1 10.122.141.100 fe80::fac2:88ff:fe1b:bf88
3.2(2l) crva- FCH1824V2VR fully-fit
4~ 10.0.0.4
you can see that my APICs are using 10.0.0.1,.2,.3,.4. You may run into issues if you try to use those IPs in your fabric as they are suppose to be used for the infrastructure.
08-09-2018 11:31 PM - edited 08-10-2018 06:52 AM
It was a subnet example only.
The concept is that I can't contract two IP virtual machines in this way:
Vlan10 - EPG-A (IP 1.2.3.3/28)
Vlan20 - EPG-B (IP 1.2.3.4/28)
Contract is ok.
If you can, do the same config (VMM Domain) in your lab.
08-10-2018 06:29 AM
Is this a typo ?
Vlan20 - EPG-B (IP 10.2.3.4/28)
From previous posts you said these were all in the same BD/subnet.
If VLAN20 VM was suppose to be 1.2.3.4 and not 10.2.3.4 that is a very straight forward setup. I would verify on your VMs if ARP is getting resolved to the other EP. The GW is not involved here since both hosts are in the same subnet. If that all looks good check rules on the leaf to make sure traffic is not being dropped.
leaf# show logging ip access-list internal packet-log deny | grep 1.2.3.3 | grep 1.2.3.4
08-10-2018 06:52 AM
It was a mistake. Post corrected!
08-10-2018 07:12 AM
This is the output:
08-10-2018 09:22 AM
Looks like its getting dropped. Are these in the same BD?
I would verify one EPG is the consumer (initiator of traffic) and one is the provider (receiver of traffic) as well as the filter allowing the type of traffic you are testing.
08-10-2018 06:36 AM
If those are actually the IPs you are using and you still want these EPGs the same BD, you can define two SVIs under the bridge domain, one for the 1.2.3.0/28 subnet and one for 10.2.3.0/28 subnet
08-10-2018 02:06 PM - edited 08-10-2018 02:08 PM
Wow - a lot of confusion here.
It seems we have two mixed threads, or a hijacked thread
Thread #1 as asked by Thursand
@Thushan Pramod wrote:
Hi All,
Thread #2 as asked by Maurlai (or what I believe was meant to be asked)
I have two hosts on the same subnet, same BD but in different EPGs with a permit all contract between them. Why can't I get them to communicate?
Now let's deal with Thread #1
And now let's deal with Thread #2
And finally, just a note about the IP addresses in the TEP space. The IP addresses used in the TEP space has nothing to do with either of these - don't let that thought distract you.
I am in the process of writing a blog post explaining how ARP Gleaning works, so if you want to know more, look out for it.
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
08-10-2018 02:23 PM
Hi All,
I hope this helps
