03-16-2017 10:47 AM - edited 03-12-2019 02:04 AM
We are using two ASA 5525X firewall and configured one HA port between firewalls. Our customer expecting Two HA ports between ASA. Please help me to configure the same ..
Muthukumar
03-16-2017 11:36 AM
Do you mean using 2 interfaces bundled in 1 port-channel?
If yes, then just create the port-channel first: (let's assume interfaces to use for HA are g0/3 and g0/4)
interface g0/3
description HA Failover
channel-group 1 mode active
interface g0/4
The port-channel interface will be created automatically by ASA. then on your failover, just use the port-channel interface created like: (only commands related to interfaces. The rest of the failover still be the same as with 1 interface)
failover lan interface fover Port-Channel1
failover link fover Port-Channel1
PS: Please don't forget to rate and mark as correct answer if this answered your question
03-16-2017 12:08 PM
whether Failover key & Ip address required please confirm.. for single HA port i have configure for the following commands and its working fine..
failover
failover lan unit primary
failover lan interface lanfail GigabitEthernet0/7
failover key *****
failover link lanfail GigabitEthernet0/7
failover interface ip lanfail 192.168.50.253 255.255.255.0 standby 192.168.50.254
Muthukumar
03-16-2017 03:05 PM
Yes as I said all other failover config still remain the same. That means you need the ip and key portion as well.
