Contact Centre Server Builds (hardening)
Mar 17th, 2017
We are in the process of deploying Cisco PCCE within our environment. However there is a sticking point on deployment of the virtual machines.
Cisco states the following
  • Packaged CCE is qualified to only work on a retail installation of Microsoft Windows Server 2012, Standard Edition. Custom Windows images are not supported.
Does the above imply that we are unable to deploy the server from our template which are security hardened (they are retail just security hardened). I read it as we are not allowed to harden the servers in any way except patch them with updates. Can someone please clairfy because we don't want to run an unsupported configuration in the environment.
Cheers
Omar Deen Fri, 03/17/2017 - 20:59
  • Silver, 250 points or more
Mayur,
What it means is that Cisco does not support the Windows Server configuration outside of what they detail in the Install Guide. What it also means is that if you have applications that need to be on that server (e.g., IBM BigFix, EMC Avamar, etc...) then go ahead and install them and/or configure the server the way you need it to, but if you have to contact TAC about an issue and they recognize something on the server that's not supported, they will ask you to remove or disable the software/service before they go any further with their support. This may not seem like a big deal, but if your call center is down and you're opening a P1 case, you don't want to waste any time.
With my experience, software doesn't seem to pose a problem... unlike these odd ball services that run in the background or crazy firewall rules or client side jobs that run in the middle of the day... it's things like that. Customers pushing back and using their own Windows Server image is not uncommon and you just hope that something doesn't go wrong after the cut over.
Since this is PCCE... just make sure nobody screws with Tomcat :)
