I have a problem with OPEN VPN, set up accounts with password+certificates which I generated from the appliance, no issues
Connects with no issues and stays connected BUT every hour or so get and error and reconnects
Using firmware - RV32X_v1.3.2.02_20160923-code
Log from the client
MANAGEMENT: >STATE:1489707600,CONNECTED,SUCCESS,****************
Thu Mar 16 20:15:15 2017 Connection reset, restarting [0]
Thu Mar 16 20:15:15 2017 SIGUSR1[soft,connection-reset] received, process restarting
Thu Mar 16 20:15:15 2017 MANAGEMENT: >STATE:1489709715,RECONNECTING,connection-reset,,,,,
Thu Mar 16 20:15:15 2017 Restart pause, 5 second(s)
Thu Mar 16 20:15:20 2017 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Thu Mar 16 20:15:20 2017 TCP/UDP: Preserving recently used remote address: [AF_INET**********:1194
Thu Mar 16 20:15:20 2017 Socket Buffers: R=[65536->65536] S=[65536->65536]
Any ideas on how to make it so that we setup longer times to re-key OR fix the problem all together..
Port?
Thanks..
