UCCX Drops some calls after Agent Pickup
Mar 19th, 2017
HI All
We use UCCX 11 and CUCM 10.5
Several times , some calls are dropped as soon as the agent picks up the call.
It may be codec mismatch or not ? we enable 722 advertise .
you can check our script attached.
BR
Remon
Chris Deren Sun, 03/19/2017 - 07:36
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Indeed sounds like a codec issue if phone rings, but call drop upon answer.  You will need to review the MIVR logs from CCX and CUCM SDL logs.
Remon Adel Mon, 03/20/2017 - 05:18
unfortunately ,at the time of this issue we didn't turn on traces .
but there are some other issues with this main issue .
1- some time this error message appear on finesse  when agent try to answer call "This operator can't be part of call"
2-some time call drop after agent pickup call and once it ring  it dropped .
3-some times after agent answer call ,agent listen to MOH not customer .
Related Content
