New IVR advise needed
Mar 20th, 2017
Hello everyone,
I've been assigned a task to create a new CSQ IVR and while I have the CCX & CM configured, I need assistance with the scripting piece.  I'm no pro but can pretty much find my way around the editor, I'm just needing some pointers.
A little background, this particular CSQ is for support line which has a different support numbers in EU, AP, IN, & NA.  The idea is that depending on which support number the customer (caller) calls it lands on the appropriate support agent on that region (if available); otherwise, they have the option to reach an English (NA) support agent or leave a voicemail.
Here's what I'm not sure if possible.  Each of the different support numbers will hit a pilot number in my NA CM.  How do I go about collecting the forwarding number so I know where the customer is coming from (without prompting them) and direct to the respective agent?  Is this possible, if not - what are my options?  I was thinking of using "Call Contact Info".
Thanks in advance.
david.macias Tue, 03/21/2017 - 06:21
  • Blue, 1500 points or more
If you use call contact info, can you tell this caller's region? If not, why don't you use a different pilot number for each region?
david
