03-20-2017 09:40 PM - edited 03-08-2019 09:50 AM
I'm configuring Qos priority and a bit confused about priority parameters. it can be given kbps or percent of the bandwidth or without any value by pressing enter directly. what is its default behaviour without giving any parameters? is it going to consume as much as possible of the total bandwidth? If that is the case, do we have to use "police" command to limit its consumption for not starving other traffic?
R1(config-pmap-c)#priority ?
<1-2000000> Kilo Bits per second
level Multi-Level Priority Queue
percent % of total bandwidth
<cr> <<<<<<<<<<<<<<<<<<< pressing enter
class-map EF
match dscp ef
policy-map pmap
class EF
priority
03-21-2017 02:11 AM
Did you try to apply it on a test interface and give a show policy-map interf ?
enrico
03-21-2017 06:03 AM
For what specific platform?
