UCCE: How to find dialed number using SQL query
Ayodeji Okanlawon
Gents,
Which table does the dialed number gets stored in. I need to know how to find the dialled number rather than manually going through each dialed number list as this can be very time consuming as you can imagine.
Please rate all useful posts
2 Accepted Solutions
you can query Dailed_Number table from Logger database . There are two columns (EnterpriseName and DialedNumberstring) in this table which will give you complete list
select EnterpriseName,DialedNumberString from Dialed_Number
Omar Deen
SELECT DN.EnterpriseName AS Peripheral, CT.EnterpriseName AS CallType, MS.EnterpriseName AS ScriptName, DN.DialedNumberString AS DialedNumber
FROM Call_Type CT, Dialed_Number DN, Dialed_Number_Map DNM, Call_Type_Map CTM, Master_Script MS
WHERE MS.MasterScriptID IS NOT NULL
AND DNM.CallTypeID = CT.CallTypeID
AND DN.DialedNumberID = DNM.DialedNumberID
AND CT.CallTypeID = CTM.CallTypeID
AND CTM.MasterScriptID = MS.MasterScriptID
GROUP BY CT.EnterpriseName, DN.EnterpriseName, MS.EnterpriseName, DN.DialedNumberString
ORDER BY DN.EnterpriseName
8 Replies 8
Sasikumar Divvela
If you are looking from which Dial Number call came, then you can get it from Route_Call_Detail table (use DialedNumberID field ) and check that ID in Dialed_Number table.
Thanks Sasikumar,
I am not looking for the dialed number in the RCD table.
What I want is this, in configuration manager you have a list of dialed numbers by name. in my environment there are lots of them. To find the dialed number associated to each list you have to manually click on the list. Is there a way to run a query to find the dialed number configured without scrolling through each list
Thank you that was what I wanted.
Glad that helped.. Have a great day..
Omar Deen
Omar,
This is brilliant, thank you
+5 Omar,
This is really cool. Very helpful in finding the mapping in case of huge no.of DN's and scripts.
