Network Management
Don't miss this Cisco Catalyst 8000 offer
Labels
At my new job, I was told RADIUS hasn't functioned for over a year.  I wiped the RADIUS server settings and started from scratch.  I'm happy to say, after going thru every cisco device, ALMOST all devices now login via RADIUS flawlessly.  There are t...
Marcus023 by Level 1
  • 239 Views
  • 3 replies
Hello,Does anyone know if there is a way to log bgp routes updates? Obviously there is a way to see adjacencies changes, but I am needing to see route updates by logging so I can send the output to a Syslog server?CheersSteven
Helo SIRplease help me, I want to add a temperature switch graph to the cacti, how do I do it? how many OIDs do I need to add to the cacti? I use Cisco WS-C2960L-48TS-LL and C9300-48T-4X-E switches, thank you
Hi We are configuring cisco devices via python. and also trying to exploring with API. When using API, there are some connection issues which are not clear yet. So I would like to know what kinds of cisco device can support API. and how can we use AP...
Leftz by Level 4
  • 426 Views
  • 5 replies
Hi Everyone I am enabling netconf on Cat9k switches and want to use a custom AAA group for it and not just the default. I have the following configuration that works, but want to change it so we use a named group and not the default: aaa new-model ! ...
Dear all,I am configuring a network cfomposed of 4 VLANs with the following devices:- NetGate 6100 Firewall- A Cisco 2951 Router- Ciscon 2960 SwitchVLANs and DHCP were configured on the 2951 router.Note that NAT function is handled by the Firewall.Af...
Koffman by Level 1
  • 85 Views
  • 2 replies
Hi All!I am currently deploying NAC in my organisation's switches and was wondering if there is a Python script to help ease this task.The commands are almost the same on all the ports, except for the dot1x/mab priority one when there's a device conn...
Zakitis by Level 1
  • 73 Views
  • 1 replies
I'm trying to have EEM script where I run the script manually and it display the output of the results in the session but for some reason I'm unable to do so. This is what I have so far(config)#event manager applet TestCommand(config-applet)# event n...
Sunny5 by Level 1
  • 363 Views
  • 14 replies
Hello!I tested PPTP and L2TP VPN solutions, but considered another solution without the Cisco router involved.I've disabled all the virtual-access and vpdn stuff,sh run all | i vpdnreturns nothing, but the ports for PPTP and L2TP are still open and c...
mo01 by Level 1
  • 344 Views
  • 14 replies
We are running prime with the version 3.10.2 and are not able to edit groups anymore.All the actions are missing on every group. We cannot edit, create or delete groups anymore. This seems to be an issue with chrome (version 117.0.5938.92) as the act...
