ā03-21-2017 12:12 PM
Cisco 2911 - LDAP Locks up after an login using incorrect password over VPN, we have to clear LDAP server using the below command for any user to connect again.
clear ldap server DC01 (DC01 is the ldap server configured)
Below is the debug when any user tries to login using correct password while LDAP is locked out.
āReceive event: read=1, errno=11 (Resource Temporarily Unavailable)"
"LDAP Search Operation result : failed"
We are using Cisco VPN client to connect. Could anyone help us to fix this or find a work around?
Rijath Mohamed
Solved! Go to Solution.
ā03-22-2017 02:02 PM
Then this is clearly an IOS issue.
I would try a gold star release such as 15.5.3M5 or 15.4.3M7.
15.6 is bleeding edge new.
ā03-21-2017 09:16 PM
What version of software are you running on your 2911?
ā03-21-2017 09:18 PM
It looks to me like the LDAP server is returning a "resource temporarily unavailable" error, and the 2911 will be knocking out the LDAP server from further consideration for a period of time - because the server is saying it is sick.
I would check the log on the LDAP server to see if it says anything interesting.
ā03-22-2017 07:09 AM
Thank you for replying, Philip
LDAP server does not log any error when authentication is failing, more over this starts happening after updating IOS from 15.2.4 M6 to 15.6.3 M1 - issue exists in the version 152-4.M6 as well.
ā03-23-2017 01:33 PM
I do not think that will work either, Phillip. We are going to test it will AnyConnect! :) thank you for helping me out.
ā03-27-2017 05:09 AM
Hi Philip,
Found a workaround for this issue:
So now LDAP on router is not getting locked if a user tries incorrect password, they are able to connect with correct password without clearing active LDAP server session
I too believe that this is an issue with the IOS code, but we are happy as long as the above solution work for us. :)
Thank you,
Rijath Mohammed
