03-22-2017 04:16 AM - edited 03-12-2019 06:20 AM
We have 5516-X ASA box with source fire module, able to access ASDM (ASA GUI) but unable to find the on-box-management feature such as FMC option in ASA configuration tab.
Kindly help.
Thanks and regards,
Ashok
Solved! Go to Solution.
03-29-2017 11:21 PM
As you mention and as confirmed by the details you posted, your module is currently managed by FMC.
You cannot have off-box (FMC) and on-box (ASDM) management at the same time.
To remove the FMC you would have to log into the module cli and enter
configure manager delete
Most customers are better served by FMC as it has superior capabilities.
03-22-2017 08:18 AM
Have you completed the initial cli-based setup of the module? That is mandatory. Please see the Quick Start guide for more details on how to perform the initial setup:
http://www.cisco.com/c/en/us/td/docs/security/asa/quick_start/sfr/firepower-qsg.html#pgfId-139738
Once you have done that, please share output of the following:
show module sfr detail
03-29-2017 11:01 PM
Sorry to have delayed response from me.
Kindly find the required details as below.
sh module sfr details
Getting details from the Service Module, please wait...
Card Type: FirePOWER Services Software Module
Model: ASA5516
Hardware version: N/A
Serial Number: JAD20430GVF
Firmware version: N/A
Software version: 6.1.0-330
MAC Address Range: a03d.6fb5.da95 to a03d.6fb5.da95
App. name: ASA FirePOWER
App. Status: Up
App. Status Desc: Normal Operation
App. version: 6.1.0-330
Data Plane Status: Up
Console session: Ready
Status: Up
DC addr: 192.168.201.17
Mgmt IP addr: 172.16.255.10
Mgmt Network mask: 255.255.255.0
Mgmt Gateway: 172.16.255.254
Mgmt web ports: 443
Mgmt TLS enabled: true
As of now the SFR is managed by FMC which is out of box management.
Thanks and regards,
Ashok
03-29-2017 11:21 PM
03-29-2017 11:49 PM
Thank you very much.
Ashok
