Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928704members
1242474discussions
Community Activity
AP2702i degrading throughput
Hi community!I posted about some 2702i in autonomous mode, degrading throughput after some time - see post: Autonomous Mode Failing on Aironet 2702i-z-k9 - Cisco CommunityLast days I got a WLC 2504 and other 2702i access points  (in controlled - LWAP...
CSCwh18572 - Headless iPSK/mPSK
Why can't Cisco catch up and do this? It is such a simple concept. Aruba, Ruckus and even Ubiquiti can all do it. I don't mind running a Radius server but dot1x is not suitable for many environments. We have events where 5000 people turn up on first ...
vManage is not enough space for updating
Can't update vManage from 20.9.1 to 20.9.2.1[1-Mar-2023 6:03:11 MSK] Device: Failed to install: Signature verification Suceeded.\nSignature verification Suceeded.\nSignature verification Suceeded.\nerror-reason 'ERROR: Error: Disk space is not enough...
dijix1990 by VIP
  • 1248 Views
  • 11 replies
Trustsec Network Authorization not Working
Hi All,I am newly building trustsec in my environment,trying to add one of the switch under trustsec. Have configured Trustsec settings and COA on the ISE for the switch and added the appropriate aaa commands , radius servers and cts commands.But sti...
Connecting CX Cloud to Meraki Dashboard
Was looking to setup Meraki dashboard as a source for input to CX Cloud.  Is any one using this?  How easy was it to set up?  Any risks or important keys to success?
I am trying to upgrade ROMMON on 4331 from 15.4(r3)s5.
I am tying to upgrade the ROMMON from 15.4(r3)s5 to isr4200_4300_rommon_1612_2r_SPA.pkgthe output I get when I type in: upgrade rom-monitor filename bootflash:isr4200_4300_rommon_1612_2r_SPA.pkg allChassis model ISR4331/K9 has a single rom-monitor.Up...
sk002 by Level 1
  • 2686 Views
  • 16 replies
C9800 WNCd
i've seen this item "Site Tags AP to WNCd distribution" in best practice of C9800 Design and Deploymentmy quiestion is how can i configure multiple WNCd and where is the location of settings in webui?
Felix5 by Level 1
  • 211 Views
  • 9 replies
End point detection
I am new to cisco endpoint and will need some help in creating rolling 3 months analysis for end point positive detectionsand also analysis for false positive detection.Any help and directions will be deeply appriciated.Thanks
neroblaze by Level 1
  • 106 Views
  • 4 replies
9800 WLC-Same Vlans on multiple sites in SD-WAN setup
I have a 9800-CL in an SD-WAN setup. I have multiple sites that have the same Vlans at each site to make it easier to manage and remember.Ex:NorthSite: data-4, voice-5, wifi-6SouthSite: data-4, voice-5, wifi-6etc...My current WLC configuration has on...
GeorgeC71 by Level 1
  • 95 Views
  • 3 replies
Mitel - DHCP Discovery
Hi, I have a Mitel 5312 phone plugged into a switchport configured for ISE but when it boots up it gets stuck on DHCP Discovery. If I put the port to authentication open then it goes through and boots up as normal.The logs all look ok but I can't see...
wifi network drops during the day - AIR-AP2802I-Z-K9
Deal All,       I would like your help regarding a problem that has been going on for a long time. Many users at the company have complained that the WiFi connection on their laptop drops several times during the day. I have been monitoring some of t...
