event manager session cli username missing
Mar 24th, 2017
I maybe missing something very simple, here where is the command "event manager session cli username xxxx" on my Nexus 7710?
n77-vdc2_AGG(config)# event manager session cli username
% Invalid command at '^' marker.
-n77-vdc2_AGG(config)#
as below my setup so far
event manager environment email_from "[email protected]"
event manager environment email_server "mailrelay.hello.com"
event manager environment email_to "[email protected]"
event manager applet track_SLA_98
  event track 98 state down
  action 1.0 cli command "enable"
  action 1.1 syslog msg IPSLA collector 98 timed out
  action 1.2 cli command "tclsh bootflash:scripts/smtp.tcl"
-n77-vdc2_AGG# show file smtp.tcl
set mail_pre "Mailservername: mailrelay.hello.com\n"
append mail_pre "From: [email protected]\n"
append mail_pre "To: [email protected]\n"
append mail_pre "Cc:\n"
append mail_pre "Subject: Multicast Tunnel down\n\n"
append mail_pre "Multicast Tunnel\n\n"
set mail_msg [uplevel #0 [list subst -nobackslashes -nocommands $mail_pre]]
if [catch {smtp_send_email $mail_msg} result] {
    error $result $errorInfo
Joe Clarke Fri, 03/24/2017 - 13:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This applet/script won't work on NX-OS.  This is clearly for IOS (and it likely wouldn't work there, either).
You could achieve what you want on NX-OS, but you'd need to port this Tcl to Python.  Alternatively, you can use the "mail" action, which I believe is in NX-OS 7.3:
action 1.2 mail from ADDR to ADDR subject "Multicast Tunnel Down" body "Multicast Tunnel"
