vWLC 8.2.130.0 mesh LWAPP 1142 keeps dropping out
p3tter123
Hi, i have a vWLC 8.2.130.0 with 1x 3602E AP and 1x 1142I AP in a bridge setup.
The 3602 is configured as flex + bridge and as a  root AP.
The 1142 is configured as flex + bridge and as mesh a mesh AP.
im trunking 2 vlans across the bridge, vlans is in transparent mode.
everything seems ok and it works fine, but after 10-15 min the 1142 AP disconnects.
Its not restarting, its only dropping the connection for some minutes, and have a interface reset.
here is the log from the controller:
I have done a restart of both AP's and the controller, but its still same behaviour.
anyone have some tips?
Number of Traps since last reset    19
Number of Traps since log last viewed    19
Log System Time Trap
0 Sat Mar 25 21:33:59 2017 Rogue AP: cc:5d:4e:15:8d:dc detected on Base Radio MAC: 58:97:1e:b2:bf:b0 Interface no: 0(802.11n(2.4 GHz)) Channel: 2 RSSI: -70 SNR: 22 Classification: unclassified, State: Alert, RuleClassified : N, Severity Score: 0, RuleName: N.A. ,Classified AP MAC: 00:00:00:00:00:00 ,Classified RSSI: 0
1 Sat Mar 25 21:31:10 2017 Rogue AP: 48:db:50:89:69:89 detected on Base Radio MAC: 08:17:35:32:6a:e0 Interface no: 0(802.11n(2.4 GHz)) Channel: 4 RSSI: -70 SNR: 24 Classification: unclassified, State: Alert, RuleClassified : N, Severity Score: 0, RuleName: N.A. ,Classified AP MAC: 00:00:00:00:00:00 ,Classified RSSI: 0
2 Sat Mar 25 21:26:41 2017 AP's Interface:0(802.11b) Operation State Up: Base Radio MAC:08:17:35:32:6a:e0 Cause=Radio interface reset. Status:NA
3 Sat Mar 25 21:26:41 2017 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:08:17:35:32:6a:e0 Cause=Radio interface reset. Status:NA
4 Sat Mar 25 21:26:41 2017 AP's Interface:1(802.11a) Operation State Up: Base Radio MAC:08:17:35:32:6a:e0 Cause=Radio interface reset. Status:NA
5 Sat Mar 25 21:26:41 2017 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:08:17:35:32:6a:e0 Cause=Radio interface reset. Status:NA
6 Sat Mar 25 21:26:41 2017 AP's Interface:0(802.11b) Operation State Up: Base Radio MAC:08:17:35:32:6a:e0 Cause=Radio interface reset. Status:NA
7 Sat Mar 25 21:26:41 2017 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:08:17:35:32:6a:e0 Cause=Radio interface reset. Status:NA
8 Sat Mar 25 21:26:41 2017 AP's Interface:0(802.11b) Operation State Up: Base Radio MAC:08:17:35:32:6a:e0 Cause=Radio interface reset. Status:NA
9 Sat Mar 25 21:26:41 2017 AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:08:17:35:32:6a:e0 Cause=Radio interface reset. Status:NA
10 Sat Mar 25 21:26:41 2017 AP's Interface:1(802.11a) Operation State Up: Base Radio MAC:08:17:35:32:6a:e0 Cause=Radio reset due to configuration change. Status:NA
11 Sat Mar 25 21:26:37 2017 Mesh node '08:17:35:32:6a:e0' joined parent node '58:97:1e:b2:bf:bf' using default bridge group name.
12 Sat Mar 25 21:26:33 2017 AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:08:17:35:32:6a:e0 Cause=Unknown Reset Status:NA
13 Sat Mar 25 21:26:33 2017 AP's Interface:0(802.11b) Operation State Up: Base Radio MAC:08:17:35:32:6a:e0 Cause=Radio interface reset. Status:NA
14 Sat Mar 25 21:26:27 2017 AP 'AP1142', MAC: 08:17:35:32:6a:e0 disassociated previously due to Link Failure. Uptime: 0 days, 00 h 49 m 16 s . Reason: Capwap WTP Event request.
15 Sat Mar 25 21:25:33 2017 Mesh node '08:17:35:32:6a:ef' has changed its parent 5 times in last one hour.
16 Sat Mar 25 21:25:33 2017 Mesh child node '08:17:35:32:6a:ef' has changed its parent to mesh node '58:97:1e:b2:bf:b0' from mesh node '58:97:1e:b2:bf:bf'.
17 Sat Mar 25 21:25:06 2017 AP Disassociated. Base Radio MAC:08:17:35:32:6a:e0 ApName - AP1142
18 Sat Mar 25 21:24:52 2017 Rogue AP: 96:53:30:1d:42:d7 detected on Base Radio MAC: 58:97:1e:b2:bf:b0 Interface no: 0(802.11n(2.4 GHz)) Channel: 1 RSSI: -75 SNR: 17 Classification: unclassified, State: Alert, RuleClassified : N, Severity Score: 0, RuleName: N.A. ,Classified AP MAC: 00:00:00:00:00:00 ,Classified RSSI: 0
Scott Fella
Why not just set the to bridge mode?  Also if you are using the 5ghz as the backhaul, set the channel to 165 or a non DFS channel. I would also set the power to max to see if the link will stay up. Also as best practice, configure a bridge group name for you mesh AP's.
-Scott
-Scott
Scott Fella
-Scott
-Scott
It worked when i created a group and added them there!
I need to use flex + bridge because im using a virtual WLC
