Showing results forĀ
Search instead forĀ
Did you mean:Ā
High CPU uses showing after updating 1002 IOS
im_badal1
High CPU uses showing after IOS update from  XE-03.08.00 s to 03.16.05.s
During boot up process it shows a error log
Mar 22 06:07:49.542 R0/0: %BOOT-0-DRV_LOADFAIL: Failed to load driver contdev ( FATAL: Module contdev not found. )
%IOSXEBOOT-4-BOOT_ACTIVITY_LONG_TIME: (rp/0): tdl_boot_time_resolve took: 109 seconds, expected max time 30 seconds
Mar 22 06:10:38.014 R0/0: %PMAN-3-PROC_EMPTY_EXEC_FILE: Empty executable used for process vman
Rommon version running is Version XNC
Any idea about the problem ?
#show platform
Chassis type: ASR1002
Slot Type State Insert time (ago)
0 ASR1002-SIP10 ok 00:06:57
0/0 4XGE-BUILT-IN ok 00:02:22
0/1 SPA-8X1FE-TX-V2 ok 00:02:24
0/2 SPA-8X1FE-TX-V2 ok 00:02:25
0/3 SPA-8X1FE-TX-V2 ok 00:02:24
R0 ASR1002-RP1 ok, active 00:06:57
F0 ASR1000-ESP5 ok, active 00:06:57
P0 ASR1002-PWR-AC ok 00:04:30
P1 ASR1002-PWR-AC ok 00:04:30
Slot CPLD Version Firmware Version
0 07120202 12.2(33r)XNC
R0 08011017 12.2(33r)XNC
F0 07091401 12.2(33r)XNC
Leo Laohoo
Rommon version running is Version 15.5(3)S5
No it's not.  It's the default 12.2(33r)XNC and according to the ROMmon Release Requirements (Table 6), the minimum ROMmon version for IOS XE 3.16.X is XND.
Post the complete output to the command "sh proc cpu sort | ex 0.00".
Leo Laohoo
Thanks for you reply. Could you please provide the download link of desire XND rommon for XE version 3.16 x?
Don't bother with XND and go straight to the latest version supported by your appliance model, 16.3(2r).
Please don't forget to read the Release Notes.
