03-27-2017 07:28 AM
We need to police traffic on BVI interface. No bandwidth or shaping, just policing ingress and egress.
Here it says that it's not supported
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r6-1/interfaces/configuration/guide/b-interfaces-cg-asr9k-61x/b-interfaces-cg-asr9k-61x_chapter_0111.html#ID-1763-0000005e
Here (version 4.3) it says that it's supported in a way
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-3/qos/configuration/guide/b_qos_cg43xasr/b_qos_cg43asr_chapter_0100.html#concept_0C713A476AC94459A98865A4191D9AAD
On 6.1.3 it does not say anything about BVI. It looks like that Cisco has removed this part?
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r6-1/qos/configuration/guide/b_qos_cg-asr9k-61x/b_qos_cg60xasr9k_chapter_0101.html
There is also a bug id about a very similar issue.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCue38896/?referring_site=bugquickviewredir
So, is it possible to police traffic on BVI with Tomahawk HW and XR 6.1.3?
Solved! Go to Solution.
06-09-2017 07:58 AM
yup yup, no problem for testing smail! believe you have 8k policers with TR's.
x
03-28-2017 02:20 PM
hi Smail,
classification, marking and policing should be supported on BVI, both on Typhoon and Tomahawk. Is it not working?
Policer at parent level can't use % when applied to BVI. Queuing actions are not supported on BVI (shaping, BW allocation, priority, manual queue-limit).
/Aleksandar
03-28-2017 02:53 PM
Hi, I have opened a TAC SR 682046542 for this issue.
The TAC engineer has told us that in case of VPLS, BVI QoS is not supported.
I have attached a diagram of my setup. If you have the time you can take a look in the case notes.
In my test I found out that only engrees traffic is matched and policed, i.e. ICMP reply
04-01-2017 02:16 PM
hi smail,
if you have a bvi in a BD with a few EFP's, the qos policy is effectively programmed on those EFP's. Same as with a bundle interface and its members.
The policy is NOT getting programmed onto the PW, because we dont know where that PW can come in on. This is btw why the PWHE config has a pindown list, so we know the expected hw interfaces to be used, so we can program the QOS and features on those hardware interfaces, again here similar as the bundle members.
so in short, you CAN use QOS, with aleks restrictions btw, but only on EFP's.
if there is a PW in play, you'd need to resort to a PWHE interface and use a pindown list for that feature association.
cheers
xander
04-07-2017 05:03 AM
I did a quick test and it's working fine. The interface where the FTP server is connected is only in the same VRF as BVI999, but not configured under L2VPN.
I have notified TAC (SR 682046542) and I was told that they will correct the documentation for 6.1.x.
Here is a drawing with config
06-09-2017 12:13 AM
Hi Xander,
we had to stay with BVI QoS without EFP's. Customer demands, nothing I can do.
The thing is that policing is working without EFP but there is a catch. There are three LC's and because the BVI is not tied to an EFP we can see matches and drops
I did a test with police 2mbps but I got only around 0.5
Could it be that I have to use police with triple value because the BVI is not tied to an EFP and the
06-09-2017 05:19 AM
correct smail, the feature on teh bvi is configured on the efp's in the bridgedomain, so what you see is correct.
you could potentially if you have designated vlans for subs, peel out the subif and define as an l3 with the control policy.
realizing that a subscriber may move from one subif to another subif if the stp converges (sub will re-establish)
xander
06-09-2017 05:42 AM
the thing with subinterfaces is that the subscriber is connected
There are only a couple of subscribers, but I do not know what could happen if I try PWHE on -TR HW.
06-09-2017 06:02 AM
hi smail,
you can cofnigure it and it works, but remember that when it comes down to qos, the qos pieces for the subs on the pwhe are programmed onto the interfaces in the pindown list. so shaped qos is pretty much out (since you only have 8 per port) and limited policers.
for BNG also you need SE linecard hardware btw.
xander
06-09-2017 07:44 AM
Yeah, shaping is out and it's not a problem. Simple policing is enough.
So I can try with PWHE on TR with around 10 PWHE interfaces and simple policing?
btw. it's an IGW running on ASR9912. For BNG we are waiting for PWHE PPPoE on Main interface feature.
06-09-2017 07:58 AM
x
06-09-2017 08:07 AM
