03-28-2017 03:47 PM - edited 03-01-2019 01:08 PM
HI All,
Im new with UCS, i have this box that i will be using as a LAB server for network simulator..
current setup is;
vmware esxi: 4.1
bios:c2001.4.3c.0
MY VMWARE ESXi upgrade path is from 5.1 to 6.5
1. first upgrade: esxi to 5.1 what version of BIOS is required?
2. 2nd upgrade: esxi to 6.0 or 6.5: what version of BIOS is required?
once i have the BIOS firmware, which one to go first upgrade the BIOS or upgrade the VM?
Marlon
Solved! Go to Solution.
03-28-2017 04:15 PM
Similar question here:
https://supportforums.cisco.com/discussion/13261466/ucs-vmware-support-matrix
Follow the interop matrix for supported firmware versions with the hypervisor.
You upgrade the UCS firmware using HUU or CIMC, BIOS, Adapter, etc.
Then move on to the hypervisor.
-Wes
03-28-2017 06:56 PM
Greetings.
You can jump from any 1.43 version to the latest 1.43 release.
Kirk...
03-28-2017 04:15 PM
-Wes
03-28-2017 05:52 PM
thanks Wes!
based on the tool:
my current setup:
current setup is;
vmware esxi: 4.1 update2
bios:c2001.4.3c.0
if i want to update to ESXi 5.1 Update 3
bios: 1.4.(3) or 1.4.(3)y
if i want to update/install new ESXi 6.0 Update 1b
Now my question can i update my bios directly from 1.4.3c to 1.4.(3)y ?? or there any specific path i need to go thru first?
Marlon
03-28-2017 06:56 PM
Greetings.
Kirk...
