03-29-2017 05:51 AM - edited 03-08-2019 09:57 AM
Our security scanner reports that the 1000v switch is running a unsupported openSSL version. I upgraded the switch to 5.2(1)SV3(2.8) from 5.2(1)SV3(2.1) per bugID CSCvb48570.
1 5.2(1)SV3(2.8) 0.0
2 5.2(1)SV3(2.8) 0.0
3 5.2(1)SV3(2.8) VMware ESXi 6.0.0 Releasebuild-5050593 (6.0)
4 5.2(1)SV3(2.8) VMware ESXi 6.0.0 Releasebuild-5050593 (6.0)
5 5.2(1)SV3(2.8) VMware ESXi 6.0.0 Releasebuild-5050593 (6.0)
6 5.2(1)SV3(2.8) VMware ESXi 6.0.0 Releasebuild-5050593 (6.0)
But the scanner is still reporting that the switch is vulnerable after the upgrade. Reports that it is running version 1.0.1t and it needs to be running version 1.0.1u or higher. Is there a way to upgrade the openSSL version?
05-09-2017 01:24 AM
Hi -
Did you manage to get any information around this? I have a similar issue.
James
05-09-2017 06:42 AM
Ended up upgrading to 5.2(1)SV3(3.1) which fixed the issue, now running version 1.0.1u. But still have an issue with the scan tool reporting that the device should not be running OpenSSL version 1.0.1, that should be upgraded to version 1.0.2 or 1.1.0.
