03-29-2017 06:13 AM - edited 02-21-2020 09:13 PM
How can I set the DNS suffixes and other DNS options to appear on the Cisco AnyConnect Secure Mobility Client adapter once the user has connected via VPN?
Solved! Go to Solution.
03-30-2017 11:13 PM
group-policy "xxx" attributes
dns-server value a.b.c.d e.f.g.h
default-domain value <default doman>
split-dns <extra domain1> <extra domain 2> ...
03-30-2017 11:13 PM
04-06-2017 07:04 AM
Thanks for your reply.
What if if I want to check the append primary and connection specific DNS suffixes instead of Append these DNS suffixes in the DNS tab? Is that possible?
Thanks.
03-27-2020 07:18 AM
Don't forget the word "value" in the command.
TO:
split-dns value <extra domain1> <extra domain 2> ...
