Cisco WAAS CM hardware requirements.
I want to ask about the CM hardware requirements.
I have a lot of WAVE devices ranging from old WAE 674 to new 294s and 594s.
I have to replace the CM which is EoS (WAE 512) with a new WAVE device.
Can i buy a WAVE 294 and use it as CM in such an environment? Or i will need a bigger hardware like WAVE 594 or 694?
Are there any limitations for using WAVE 294 as CM for future upgrades?
Anand
jbejaranos976
Hello Anand,
Please consider this link: https://supportforums.cisco.com/discussion/11153586/waas-central-manager-positioning
If you are concerned about the software version, they are still supported:
http://www.cisco.com/c/en/us/td/docs/app_ntwk_services/waas/waas/v623/note/waas623xrn.html#24545
Hope this helps!
Jorge
PD: Rate it if it was useful for you so other people can use it in the future
