04-03-2017 07:55 AM - edited 03-17-2019 09:58 AM
My company is moving to VOIP phones and we were asked to disable SIP-ALG. I ran the command and performed the test that the company wanted me to run. In the test results it's still showing the SIP-ALG is enabled. Has anyone ran into this issue? Below is the command I used .
04-03-2017 02:05 PM
no ip nat service sip tcp port 5060
no ip nat service sip udp port 5060
That's how to disable ALG on Cisco routers.
10-06-2021 07:23 PM
Can you describe what would be possible impact if we execute these commands in our router in production?? Thank you.
03-13-2018 04:44 AM
What is your Cisco router series?
Thanks.
Best Regards.
Ben
04-03-2023 10:47 AM
how Do I disable sip alg for a range of ports on cisco C921-4P router ?
no ip nat service sip tcp port-range 6100 6200
% Invalid input detected at '^' marker.
Please advise
