04-03-2017 10:35 PM - edited 03-08-2019 10:02 AM
Hi i would like to know if i have an order
ws-c3850-24s-s 2 each
ws-c3850-48t-s 2 each
ws-c3850-12x-s 2 each
Could be them stackable together ?
Solved! Go to Solution.
04-03-2017 11:51 PM
From Cisco.com documentation:
"StackWise-480 supports a mixed stack of any Catalyst 3850 models (48 ports 10/100/1000, 24 ports 10/100/1000, and 12/24 Ethernet SFP ports; see Figure 1). You can mix the switches with different number of access ports (48, 24, and 12), different type of access ports (copper and fiber, PoE, and non-PoE-capable), and different network modules. But all switches in one stack must have the same version of IOS XE and the same feature set license. A mixed stack of LAN base switches with IP base or IP services is not supported. Catalyst 3850 Series Switches with a LAN base feature set can only stack with other Catalyst 3850 Series LAN base switches. The same applies to IP base and IP services as well"
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/white-paper-c11-734429.html
04-03-2017 11:51 PM
