04-06-2017 12:13 PM - edited 03-17-2019 10:01 AM
We an issue where it appears as though employees may be leaving the phone off-hook after paging and my be doing so on purpose to tie up the system. The paging system uses an FXO port off of a Cisco Voice Gateway router.
When this happens I need to get on the router and shut the port and bring it back up to resolve the issue.
Does anyone know of a way that I can just terminate any connect that has been established for 60 seconds automatically? I need a solution that is not manual.
04-06-2017 12:29 PM
This might be helpful,
Try to use different disconnect methods for FXO so that line is cleared when user drops the call.
http://www.cisco.com/c/en/us/support/docs/voice/analog-signaling-e-m-did-fxs-fxo/8120-fxo-disconnect.html
Please rate and mark correct as applicable <<<<<<<<<<
Haris
04-06-2017 12:38 PM
The issue is that they are not always hanging the phone up once they complete the page. IE they dial 50 to initiate a page and then they leave the phone off-hook. Could be a disgruntled employee whom is looking to tie up the system, but not certain.
