04-12-2017 08:36 AM
Hi all,
My Cisco CCO ID is having a problem with Set Install/Service Location parameters.
The “Default Install Site and Default Service Location” always are UNITED STATES, although I tried to set it in to VIET NAM and saved. Whenever I do create a new estimate those parameters always return to UNITED STATES by default.
Please review the attached document and If you have any suggestions please advise me.
Thank you,
Tuyen Nguyen
Solved! Go to Solution.
04-19-2017 07:11 AM
Go to My Profile and Preferences -> Preferences -> Addresses
Add an address in Vietnam in the "Shipping Address" and "End Customer Address" tabs.
It is done.
Then go to "Set Install/Service Location" of a new estimate and check the country. It must have changed to Vietnam. You can now go back to My Profile and Preferences -> Preferences -> Addresses and delete the addresses. The system has kept the Vietnam country and you are ok.
BR
Pavlos
04-19-2017 07:11 AM
It is done.
BR
Pavlos
04-19-2017 08:22 AM
Thanks Pavlos.
