04-12-2017 01:28 PM
Our SNTC portal seems like it has been updating, but it does not show the history under Upload Processing. New devices are being discovered and added to the portal and that is what leads me to believe that it is in fact upload. However, I would like verification of the upload status. What should I do to get this history and verification?
Solved! Go to Solution.
04-19-2017 08:11 AM
Hello Nathan,
I noticed that your inventory has segments and it appears that you may have selected one of the segments to view the reports.
Can you go to your Global Filter Selection for Inventory and Segment, and Select Inventory as opposed to the Segment and then try the Upload Processing View?
Let me know if you face any issue with this.
Suchita
04-13-2017 11:46 AM
Hi Nathan,
Please use PM method (use below link) and provide me Customer name, collector id and Inventory name. I will update you further.
https://supportforums.cisco.com/blog/13237466/how-send-private-message-sntc-community
Supriya
04-18-2017 11:26 AM
Hi Nathan,
You confirmed that under upload processing, you can see upload history for Inventory that you mentioned.
Supriya
04-19-2017 07:51 AM
No, there is not any history indicated under Uploading Processing. The only information that is listed is "No Data The grid returned no rows due to the query or filters."
No filters have been applied.
04-19-2017 08:11 AM
Hello Nathan,
Suchita
04-19-2017 10:23 AM
That seem to be the issue. When restricted to a single segment, it was not displaying uploads under the Upload Processing. After changing the view to include all segments, I can now see all the uploads. I do see a potential issue. There is a upload that has a Processing Start date of 4/2 and the status is still "In Progress"
04-19-2017 10:35 AM
Hi Nathan,
Yes, we noticed that other issue with upload from 4/2 being stuck because of some back-end issues, and have started the work to clear the same.
We will also work on getting the latest upload from queue processed, and let you know once it is complete.
Apologies for the inconvenience!
Suchita
