Polycom RealPresence Trio 8800 on CUCM 11.5
Scott Hanson
Level 3
Level 3
anyone have any idea how to add this phone into CUCM 11.5?
Thanks in advance
All replies rated
7 Replies 7
Jaime Valencia
http://community.polycom.com/t5/VoIP/Trio-8800-registration-to-CUCM/td-p/80885
https://supportforums.cisco.com/discussion/13011506/polycom-8800-3rd-party-sip-registration-issue
java
if this helps, please rate
rakeshksinha
1) Create local user in CUCM, "Digest Credential" is important field
2) Create device as 3rd party SIP device (Adv), with owner and Digest user added
3) web to trio IP and setting >> Lines / Authentication (USer id and Password) / Server-1 (IP of SUB where it is registered)
We have Trio C60 and don't see "Lines" option under Setting. Can someone help.
davisjaron
I just actually made a write up about this on my blog.  Granted I did it with CUCM 10.5.2, but I wouldn't suspect anything would change on 11.5.
https://ijustcant.today/?p=272
Please rate this post as helpful if you find it as such and feel free to check out and comment on my blog!
Just an update, I'm on version 12.5 now, and it's still working properly, so the guide will still work.
Hi @davisjaron do you still have this blog instruction available?
Hi, for this link is not usable, can you share another link.
