04-13-2017 09:36 PM - edited 03-01-2019 01:09 PM
Following errors appears on the console:-
CIMC Server is good
3:2017 Apr 13 08:47:10:BMC:dataserver:3793: 4/13/2017 8:47:10 DataServer -LogAgent::processGet() - can't close dir /var/log.
3:2017 Apr 13 08:47:27:BMC:dataserver:3793: 4/13/2017 8:47:27 DataServer -LogAgent::processGet() - can't close dir /var/log.
3:2017 Apr 13 08:47:34:BMC:dataserver:3793: 4/13/2017 8:47:34 DataServer -LogAgent::processGet() - can't close dir /var/log.
Would like to know what is the cause and how to get this fixed.
04-14-2017 03:17 AM
Greetings.
What is the actual impact to your OS/environment?
Kirk...
04-14-2017 03:44 AM
Thank you for getting back to me, Kirk.
There is no impact to my Customer's Environment.
However, we would like to know where does this error come from?
What does it actually mean?
04-14-2017 05:13 AM
Greetings.
I would not pay much attention to that particular log unless you are trying to correlate something else from the sel log or some other specific error or failure.
Many of the entries are just verbose logging for a number of processes and normal behind the scenes Linux log type output.
Kirk...
04-14-2017 05:37 AM
Thank you so much.
