Nexus 1000v; VSD (Virtual Service Domain) config missing
rapik
hello everybody.
 according to the doc
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus1000/sw/5_x/security_config/b_Cisco_N1KV_VMware_Security_Config_5x/b_Cisco_N1KV_VMware_Security_Config_5x_chapter_011.html
 there should be a VSD feature.
 but i cannot find any commands mentioned the doc
nexus-vsm(config-port-prof)# v?
  vmware    VMware configuration
  vservice  Bind vservice to port-profile
nexus-vsm(config-port-prof)# virtual-service-domain test
No token match at '^' marker.
 has any body familar with VSD?
Kirk J
Please note: http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus1000/sw/5_2_1_s_v_3_1_1/release/notes/n1000v_rn.html
Virtual Service Domain (VSD)VSD is no longer supported as of this release. You must remove the VSD feature before upgrading to Release 5.2(1)SV3(1.1)
Kirk...
9 Replies 9
Manish Gogna
This feature was introduced in 4.0(4)SV1(2) , so please ensure that you are running this or a higher version and also can you please share screenshot of all the config steps that you attempt including the ones for VLAN.
Manish
hi Manish thank you for your answer. pls find attached show tech-sup and the missing show and config commands at the end of this log.
Was the config as per the following attempted?
switch# config terminal
switch(config)# port-profile webserver-inside
switch(config-port-profile)# switchport mode trunk
switch(config-port-profile)# switchport trunk allowed vlan all
switch(config-port-profile)# virtual-service-domain vsd1-webserver
switch(config-port-prof)# no shutdown
switch(config-port-prof)# vmware port-group webservers-inside-protected
switch(config-port-prof)# service-port inside default-action forward
switch(config-port-prof)# state enabled
switch(config-port-prof)# show virtual-service-domain vsd1-webserver
Manish,
 the issue is there is NO any vitual-service-domain commands in the Nexus CLI.
 you can try it by yourself
 ssh://212.42.193.5  admin/admin123#
Yes, i tried and faced the same issue, the command did not work. Any chance of testing it on a different NX-OS version by upgrading or downgrading it?
Manish
it's the latest and the only one which supports esxi 6.5
Kirk J
Kirk...
Thanks for solving the mystery Kirk :)
Manish
Hi Manish,
 any comments? have you managed to access the nexus in my lab?
