04-17-2017 08:03 AM - edited 03-08-2019 10:13 AM
I do not see any drops in the following output except for the ones on the network port. Could someone please tell me what these drops represent and if it is an issue?
The switch stack is 3650s and running code - 3.06.06E
sh platform qos queue stat te 1/1/3
DATA Port:0 Enqueue Counters
Queue Buffers Enqueue-TH0 Enqueue-TH1 Enqueue-TH2
0 0 0 0 13753783225
1 0 0 0 53963041
2 0 0 0 17810121481
3 0 0 0 0
4 0 0 0 0
5 0 0 0 0
6 0 0 0 0
7 0 0 0 0
DATA Port:0 Drop Counters
Queue Drop-TH0 Drop-TH1 Drop-TH2 SBufDrop QebDrop
0 0 0 0 0 0
1 0 0 0 0 0
2 0 0 0 0 0
3 0 0 0 0 0
4 0 0 0 0 0
5 0 0 0 0 0
6 0 0 0 0 0
7 0 0 0 0 0
AQM Broadcast Early WTD COUNTERS(In terms of Bytes)
PORT TYPE ENQUEUE DROP
UPLINK PORT-0 N/A 0
UPLINK PORT-1 N/A 0
UPLINK PORT-2 N/A 0
UPLINK PORT-3 N/A 0
NETWORK PORTS 261 261
RCP PORTS 0 0
CPU PORT 0 0
Note: Queuing stats are in bytes
Thank you.
04-17-2017 08:46 AM
Is there QOS policy configured for interface 1/1/3?
Can you post it?
04-18-2017 10:10 AM
Here it is:
interface TenGigabitEthernet1/1/3
description uplink to
switchport trunk allowed vlan 1120,2120
switchport mode trunk
udld port aggressive
channel-group 20 mode active
service-policy output pmap-10G-out
class-map match-any video
description matches video traffic af41
match ip dscp af41
match ip dscp af42
class-map match-any voice
match ip dscp ef
match ip dscp cs5
policy-map pmap-10G-out
class voice
priority level 1 percent 1
class video
priority level 2 percent 2
