Accessing ASDM via Inside interface thru site-to-site vpn
chanccmtech
Good Day All,
I had a searched thru the forums looking for a very specific answer, however I can find similar topics regarding to it, but still unable to solve the issue I am currently facing.
Looking at the above diagram, user from 192.10.10.0/24 segment wants to access ASDM of firewall 192.168.51.1 via inside interface. User from that segment is able to communicate each other without any issues, but unable to access ASDM via inside interface. What else in my configuration could I still be missing. Let's just assume I have my ACL in place already.
I have enabled the following:
management-access inside
http server enable
http 0 0 inside
http 0 0 mgmt
nat (inside,outside) source static NETWORK_OBJ_192.168.51.0_24 NETWORK_OBJ_192.168.51.0_24 destination static NETWORK_OBJ_192.10.10.0_24 NETWORK_OBJ_192.10.10.0_24 no-proxy-arp route-lookup
What else could I still be missing? Pointers would be great.
ajay chauhan
Level 7
Level 7
You should also have -
http remote_subnet outside
This article may help.
http://www.cisco.com/c/en/us/support/docs/security/adaptive-security-device-manager/118092-configure-asa-00.html
Ajay
I have gone through that article before. Doesn't the command:
http 0 0 inside - covers any IP accessing inside interface?
Although by allow "http remote_subnet outside" that is pointing towards the outside interface rather than the inside interface?
Remote subnet is not local hence you should put that on outside. You can simply try that.
Ajay
