What is BE6k or BE3k
Answered Question
Apr 18th, 2017
Can anyone tell me what is BE6k, BE3k is it a hardware? or is it a package with Hardware, License
I am somewhat new to Cisco Voice, I know UCS and MCS is nothing but Hardware where we build up the VM and then install the iso image downloaded from Cisco site and then we go for Licensing it, can anyone please tell me this basic thing without sharing the Link which I am finding hard to understand
Once I had logged into BE3k to check few things but it was very dull Interface, and I was told to check something on BE6k, so thinking of the previous Experience BE3k I was expecting little more upgraded but it came out to be CUCM 10.5, I got confused
By now you can understand I am in which level of Cisco VoIP, So please help.
Correct Answer by Jaime Valencia about 4 days 21 hours ago
No, a TRC means that Cisco tested that specific HW combo, you cannot add/remove/deviate/change from what is offered, unless you want to lose the TRC level support.
Yes, if you need a solution that will go over 2,500 endpoints, you'll need to buy a new solution. If you choose to go over that, lose Cisco support due to violating the maximum number of endpoints supported by the solution.
Correct Answer by Jitender Bhandari about 1 week 2 days ago
Hi Anthony,
BE6K is a Tested Reference Configurations (TRC), which means Cisco has done enough testing and guaranties performance. You cannot use MCS anymore as UC application requires virtualization 3rd-party Specs-based category see below for details.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtual...
(Rate if it helps)
JB
Overall Rating: 5 (3 ratings)
Anthony Vinod Wed, 04/19/2017 - 01:40
Thank you Jitender.
I was just going through the link, it is mentioned BE3k works on MCS and BE6k on USC220
BE3k is totally different where they have bundled everything for very small scale organisation and also the interface is very easy(user friendly), my question is how and what does cisco delivers if we order BE3k, is it that MCS server with few other softwares specially made for BE3k? if that is the case cant we build CUCM on the same hardware?
BE6k is also coming with limited user and endpoints package which works on UCS server. but they have mentioned we can buld cucm and unity and etc etc upto 9 applications. how are Cisco again going to deliver this? are they going to deliver UCS server and the iso files of cucm and unity through the link by how they usually do, If so who decides which CM version. and it everything is same why is it named sperately as BE6k
I am really confused, I agree this questions may sound funny to some, but please help
Anthony Vinod Thu, 04/20/2017 - 00:03
Hi JB, my question if they are giving bundled solution of BE3k in MCS and BE6k in UCS, can we change the version of cucm ver, number of user licences, endpints etc etc in future as per requirement, If yes then do we really require to for BE series, why cant we directly go for MCS and UCS server and thn deploy
Correct Answer
Jitender Bhandari Thu, 04/20/2017 - 00:13
  • Cisco Employee,
Hi Anthony,
(Rate if it helps)
JB
Jaime Valencia Thu, 04/20/2017 - 09:11
  • Cisco Employee,
  • Hall of Fame,
    2011
6K is a bundled HW/SW solution, it only supports up to 1,250/2,500 endpoints depending on the platform you choose, you can find plenty of info in the BE documentation online on all the limits it has. Usually it comes with the latest versions installed. You're free to use other version if you want, you can add user licenses (up to the maximum capacity)
7K are TRC servers for regular deployments, which follow regular SRND rules, no limitations.
If you're looking to buy a solution, unless you're a Cisco partner, you won't be doing any purchase yourself, the partner/distributor will do this, and they can provide you assistance in choosing the right solution for your needs.
Anthony Vinod Mon, 04/24/2017 - 04:58
Hello Jaime, Thanks for your reply
6K is HW/SW bundled solution which is running on UCS Server 220
they have bundled collab applications, licenses with limitation of endpoints to 2500, Is it like if my company wants to add the 2501th endpoint I have to all the way buy a new server. Can't I make any changes? can't I go for addition of licenses
If yes, I can buy UCS220 or 240 seperately and build my own configurations and add licenses per my requirement, why does anyone need Buisness edition? just because it comes with pre installed CUCM,CUC,CER etc etc softwares?
Please correct me if I am wrong
Correct Answer
Jaime Valencia Mon, 04/24/2017 - 07:02
  • Cisco Employee,
  • Hall of Fame,
    2011
Anthony Vinod Mon, 04/24/2017 - 21:08
Great, Thanks for your reply Jaime
Appreciate your help in clearing my doubts
Jaime Valencia Wed, 04/19/2017 - 08:38
  • Cisco Employee,
  • Hall of Fame,
    2011
That not quite right, the 6K is not a legacy product, and the replacement is not the 7K, they're positioned for different size deployments ad they're both in CCW right now to order.
Anthony Vinod Wed, 04/19/2017 - 01:46
Thank you Jitender
I am really confused, I agree this questions may sound funny to someone, but please help
