nexus 3548 span destination multi port
jerryting
Hi Sir
I have issue with span in nexus 3548.
N3K(config)# monitor session 2
N3K(config-monitor)# source vlan 136
N3K(config-monitor)# destination interface ethernet 1/41
N3K(config-monitor)# destination interface ethernet 1/42
ERROR: Eth1/42: Only one destination per session
N3K(config-monitor)# destination interface ethernet 1/41 - 42
ERROR: Only one destination per session
N3K(config)# monitor session 3
ERROR: vlan 136: Vlan is src in another session
Any one Know how to resolve this issue?
chien-hung lin
I also have the same situation, the destination port can only set one, is there a way to solve?
version 6.0(2)A6(7)
monitor session 1
source interface Ethernet1/17 both
source interface Ethernet1/18 both
destination interface Ethernet1/43
no shut
Or like Mark Malone
https://supportforums.cisco.com/discussion/13008666/nexus-3548-span-multipale-destanation-interface
You can have multiple sources but you cant send the capture to multiple destinations same as ios , limitation exists in nx-os as well , 1 destination per session
thank!
chien-hung lin
version 6.0(2)A6(7)
monitor session 1
no shut
Or like Mark Malone
thank!
