04-18-2017 11:20 AM
I configured some policy services for Voice and Video, but I don´t know how to verify if it works correctly, could anyone help me with this doubt please:
These are my policies configure on a Fastethernet interface:
Service-policy output: Core_QoS_Egress
Class-map: Voice_and_Video (match-any)
0 packets, 0 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: dscp ef (46)
Match: dscp af41 (34)
Match: dscp af42 (36)
Match: dscp af43 (38)
Match: dscp cs3 (24)
Queueing
queue limit 8750 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 0/0
bandwidth 35% (35000 kbps)
Class-map: High_Priority_Data (match-any)
0 packets, 0 bytes
Match: dscp af21 (18)
Match: dscp af23 (22)
Queueing
queue limit 5000 packets
bandwidth 20% (20000 kbps)
Class-map: Signaling (match-any)
0 packets, 0 bytes
Match: dscp af11 (10)
Queueing
queue limit 3750 packets
bandwidth 15% (15000 kbps)
Class-map: Low_Priority_Data (match-any)
0 packets, 0 bytes
Match: dscp af12 (12)
Queueing
queue limit 2500 packets
bandwidth 10% (10000 kbps)
Class-map: Network_Control (match-any)
0 packets, 0 bytes
Match: dscp cs6 (48)
Match: dscp cs7 (56)
Queueing
queue limit 1250 packets
bandwidth 5% (5000 kbps)
Class-map: class-default (match-any)
12 packets, 1046 bytes
Match: any
QoSLab#
04-18-2017 12:17 PM
you can generate traffic by ping through TOS and see it hit your queues if its a software LAB
so below pinging with TOS vlauer of 184 generates DSCP 46 for EF traffic
#ping
Protocol [ip]:
Target IP address: 1.1.1.1
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: vlan 1
Type of service [0]: 184
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
https://www.google.ie/search?q=dscp+tos+values&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjGtOTP267TAhWoDcAKHZYxC7cQ_AUIBigB&biw=1352&bih=673#imgrc=OnJ1shJQhg_anM:&spf=191
04-18-2017 07:23 PM
Thank you so much!, that was exactly what I needed it.
