04-19-2017 01:20 AM - edited 03-18-2019 01:00 PM
Dear All,
I am facing issue on incoming caller id, when some body tries by dialing my sip uri from H.323 endpoint. I am getting incoming caller id as recipent@my ipadd. for sip incomoing calls i am getting proper recipent caller id. Kindly advice me how i can remove the IP address.
04-19-2017 06:47 AM
The H323 endpoints are able to dial a SIP URI, though the endpoint started the call as H323, so the it will show only its E164, then the IP address of your server is added when Interworking from H323 to SIP is done. In other words, this is expected.
04-20-2017 01:03 AM
Thanks for your information @Elsevil [+5]
Is there any way we can remove the IP address of our server when recieving incoming calls?
04-20-2017 05:37 AM
You can use an interworking option on VCS and configure necessary transform to match and conver the ip to domain and then send call via that search rule to allow only SIP.
I think this will fix the problem.
Alok
04-20-2017 06:35 AM
Use the following transform to replace the IP address of your VCS of the incoming call with our domain.
04-24-2017 04:37 AM
Dear Patrick,
If i create this rule, will it affect SIP incoming calls.
04-24-2017 05:05 AM
It will apply to all incoming calls, H323 and SIP, but only if the IP address that appears after the @ matches any that are assigned to your VCS.
