UCCX, licenses
siwar.ziadi1
Hi, i have a cisco unified contact center solution with 25 agents (25 premium licenses), I want to use the socialminer but I don’t know what licenses I will use to activate this service, and about the cisco unfied intelligence center what licenses I need  ?
Hi siwar,
if you have the Premium License, you can use the SocialMiner.
The only thing that you must do is to install the SocielMiner and then Configure the UCCX to get to the SocialMiner and that it.
Kind regards
Benjamin
Leszek Wojnarski
Check out slide 10 from the PPT.
It should help.
Leszek
Thank you for your answer, but I found in the datasheet that socialminer needs licenses per users and license per server, and that the per-user licenses are included in the premium license, so now i think that i need the license per server??
Hi siwar,
Kind regards
Benjamin
Thank you very much for your answer and for your help :)
